I will give you some good advice to get started with these cars. Buy a scanmaster from Turbo Tweak asap. Neat little scan tool for $225. It will display most of what ecm sees like o2 millivolts, knock retard, coolant temp, blm's, rpm, speed, tps volts, iac counts, maf counts, present engine codes, and so on. It installs in about 5 minutes with 3 wires to connect. Stock 3 core radiators for these cars are expensive ($500 up).
