I recently picked up a T type that has several mods done to it:
55 lb injectors
PT54 Precision turbo
TH downpipe
Turbo saver oil filter relocation kit
Champion ported irons
Accufab throttle body
duals with Flowmasters
Definately around a 3K stall
And I am sure a few others...
The tranny has an oversized pan with cooling tubes built into it and shifts nice and solid.
I went into 1st manually yesterday to run the boost up and break the tires loose, and the car would go nowhere. It was locked in place. If I am in 2nd, D or OD, I begin in 1st and go through every gear to the specific gear that I am in.
One person that that I had asked about this, believes I have a trans brake in the tranny, that when in 1st - the tranny goes into 1st and reverse to hold until it is slammed into 2nd.
Could someone help me identify if this is true? I want to make sure that I am not about to bust something up.
Thanks all,
Mike
55 lb injectors
TH downpipe
Thanks all,
Mike
