SignUp Now!if you take it off and rmove all the plugs, the rear brake line attachment you will see has a brass seat instead of the regular iron like the rest. this will push out the front plug that you removed. I removed this and cut it so just the rear brake line seat remained and reinstalled it. This way the pressure will equalize between the front and rear lines. This is what Bruce on turbobuicks.com did to his and that man was a genius
Gary
Retains a minimum brake line pressure to eliminate excessive brake travel in both disc and drum brake systems. Use the blue 2 lb. valve in disc brake applications where the master cylinder is located below the horizontal plane of the calipers. Use the red 10 lb. valve for drum brake applications (extra pressure compensates for return spring tension in the drums).
Wilwood 260-1876 - Wilwood Residual Pressure Valves - JEGS
this is what i am using before i upgrade the rears to wilwoods like the front! then you use the 2lb valve
nothing with the fronts...So you put that red valve in series with the rear drum brakes. What do you do with the front brake lines?
