Jan 2, 2015 #1 B Black Mamba 85 Member Joined Oct 29, 2013 Messages 49 does the 85 gn have a map sensor plug in???
Jan 2, 2015 #2 B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Messages 3,589 Yes. The MAP sensor is on the passenger side on the inner fender rail.
Jan 2, 2015 #3 O O SO LO Well-Known Member Joined Apr 22, 2006 Messages 1,591 http://www.gnttype.org/maint/8485sens.html
Jan 3, 2015 #4 B Black Mamba 85 Member Joined Oct 29, 2013 Messages 49 thanks couldnt find the location on prodmand..... what map are you using?? O SO LO said: http://www.gnttype.org/maint/8485sens.html Click to expand...
Jan 3, 2015 #5 O O SO LO Well-Known Member Joined Apr 22, 2006 Messages 1,591 using the stock map... the link shows where all the sensors are located in the engine compartment.
