max boost?
Cleaner13
The Cleaner
what is the max boost you can run with 93 pump gas and a stock GN
I only have an intake on and some gauges, I think the guy before me put on a gutted cat as well
but I am just wondering what I can run safely because I have a boost controller coming to me very soon.
also just out of curiousity what is the boost max on the car stock?
my gauge shows 11psi at WOT
should it be that much or more?
thanks
Carl
stock fuel doesn't like you to go above stock boost ;) And stock boost should be 15psi.
I would invest in a Scantool if I were you before messing with the boost.
I currently run 19-20psi in 1st and 2nd and drop it to 16psi in 3rd with 20 degrees timing at WOT.
I have a big neck intercooler, and a 3.5" singleshot but I'm still running the stock turbo and downpipe with an unopened motor.
Charles Brooks
