turbobob924
- May 28, 2001
Hey guys
Look at my sig for my GN.
What predictions for max horsepower and max boost levels??
I just did a little testing run during lunch with the 5.6 TT chip @ 18lbs. Getting up to 90% duty cycle on the 60 lb injectors. Around 19 degrees of total timing and around 25% E85. The 93 gas here already has 10% E added.
I doubt I'm making that much power at 18lbs on my 4.2 V-6. In only have pocket ported stock heads.
What's really goofy is that I only changed out the chip and injectors, from 50's with TT SD chip to 60's with TT5.6 chip. I think the WB showed 11.2 at WOT.
I was hitting 90% DC with the 50's as well.
So I added 20% more in injector and still am at the same place?? I did not think I was that lean before?
Maybe i need to use up all the gas and just try 50% Race gas and 50% 93?
