The newer style units have 2 different mounting plates. One is angled and the other is straight. If I remember correctly the stud spacing on the bracket needs to be removed and a custom bracket installed which shouldnt be hard to make, just a plate with new holes drilled but I don't know if it can be removed without removing the rod which I don't want to have to do. I don't have a problem with cutting the rod and threading it making it adjustable. I also read that the end of the rod is larger, creating slop on the brake pedal which I'm sure could be sleeved with something from a hardware store. I suppose I could have an extension bracket made to make it a direct bolt on with no cutting of the rod, but that brings up the question of the cast master cylinder having enough space to not hit the pump resevoir. I don't think it would but who knows.
