UR50SLO
The Reaper
- Jun 12, 2001
Hey guys...
Small problem that I need to track down.
Tip in throttle is ironed out.
But at mid throttle all the sudden the Injector duty cycle blips high and
AFR's go low.(rich)
Not sure what's causing it but it's not there if you "roll" into the throttle.
A quicker down on the throttle always seems to make it happen.
How low do we need to set our AE MAP Limit? I read that that can cause this
rich issue on our turbo cars.
Anyone else ran into this mid throttle rich blurp?
250CID Hyd. roller 214/218 Champion ported heads and newer champion
intake 83lb/hr inj. 76GTQ. 93oct. gas. TH400Trans.
Thanks for any tips,
Scott~
AFR's go low.(rich)
Scott~
