Misc. Parts One More Time...
57loboy
cars,trucks&tractors-ohmy
Wanted to give one more shot here before I list them on eBay as several people expressed interest when originally listed… :smile:
1) VDO 2 5/8" 2-30psi boost gauge with single gauge holder (not A-pillar), is missing the bracket that holds it in place from behind - $15 shipped
2) 3 Gauge Package in a 3 gauge holder (not A-pillar): Auto Meter Auto Gauge 2 5/8" #2312 0-100psi oil pressure gauge, Auto Meter Auto Gauge 2 5/8" #2313 100-280deg water temp, Auto Meter Auto Gauge #2310 2 5/8" Combination Boost/Vac Gauge (boost goes to 30psi) - $50 shipped
3) Weight box for racing, held 4 bags of shot with room for 4 more - nice, but I don't race and its not as good as my milk crate to sit on - $20 plus shipping
4) 84/85 throttle/TV cable bracket (for intake) - $15 shipped
5) IAC harness extension - (about 6" long) was used to extend the reach of the IAC plug when previous owner switched from an 86/87 intake to an 84/85 (yes, really!) - $15 shipped
6) TPS harness extension - (about 6" long) same purpose/reason as above, yet for the TPS - $15 shipped
7) Ignition module harness extension - the one that plugs in under the coil pack, same purpose/reason as the IAC and TPS above - $15 shipped
8) Complete 84/85 throttle body, includes TPS and IAC - $35 shipped
9) 84/85 intake - complete, includes thermostat neck and whatever sensors are screwed into it, but no fuel rail or injectors - $55 shipped
10) Fuel rail from 84/85 intake with modified end to accept #10 braided steel line - $30 shipped
PayPal preferred, Postal MO is ok too…Thanks!
Gauge Holder
is the triple gauge holder an A-pillar mount?Where in CT are you located?Thanks,AJ
It is not an A-pillar unit, it is horizontally mounted. I am in Newtown...
I am looking to replace my 2 pod A pillar with the three pod one.Thanks anyways,AJ
Is the ignition module extension long enough to mount everything on the fender? If so let me know your paypal and ill take it...i hate the stock location. Thanks
Don - pic of the gauge on its way to you
Camaro75 - the harness was long enough to move the coil/module assembly from the back of the engine to the front with slack left over. Not sure if it'd reach as far as the fender due to the master cyl and such taking up space... I can measure and send a pic if you're still interested...
That would be great...i dont like the way its mounted on the front of me motor on my 85 GN and would like to relocate...any pics would be appreciated. Thanks
#1 VDO Boost Gauge
#3 Weight Box
#4 Bracket
#8 Throttle body
#9 Stock intake
#10 modified fuel rail are all still available - will list on ebay at end of week - make an offer I might just take it! Thanks! ;)
Everything is now up on ebay (actually put a few more things up there I found laying around too!) - seller name is same as handle here...
