I've been mixing 5 gallons of E85 and about 6.5 gallons of 93 for months now on my daily driven Talon. Here is a nice link to some info, insert 110 octane for E85 and take into account what Month it is and where you live so you know if you're on E85 blend 1 or 3 etc. All this does is change the potential octane and slightly alter the AF/R.
Miles Per Dollar Calculator
It's easy for me, dump in a 5 gallon jug of E85 and then fill up = Blend is consistent in this aspect.
I added 8psi of fuel pressure (up to 44psi line off) and that helped a lot. I also have a Translator so that made it easier to dial in the Idle, 3-8psi and WOT AF/R. I use the Scanmaster to see how things are reading and it's been great.
For the GN I'd run 10 gallons of E85 and the rest 91 Octane. This way you can get two 5 gallon jugs and bring them home after the fill up at the station.
I'd consider contacting Eric for a blended chip, then with Fuel Pressure and a Translator should be all you'd need to tweak things. Wideband would be nice since this time of year will yield the closest blend of 85% Ethanol, from here you'll only get richer as the blend changes and lose some Octane.
Don't tune this to the edge of detonation, not wise.
FWIW, I not only blend E85 with 93 Octane, but run Meth Injection on top of this, fun. :biggrin:
