Mobil 424
85 Riviera
I have a few Qs before I try this out
1. will this fluid (Mobil 424) cause better shifts cold as well as hot
2. is there any negative side effects to the trannys life from using this fluid
3. well i guess thats it;) Thanks for your input
Oh I was hoping that the mobil 424 would be more consistant through temp changes, Right now I got plain ol dexron and my part throttle shifts soften just a tad but are still really firm just not as firm after about 30 minutes of driving. My full throttle seems to stay the same hot or cold so I'm assuming the dexron is thinning out with the heat. Well I guess I will just try the 424 and see what happens, I hope it cures my moody trans
To answer your first ?, yes it should cause more stabil shifts from cold to hot. No side effects that I'm aware of. Your welcome too. :D
