More detail questions regarding items on the right front frame rail.
GNVAIR
First question is placement of the plastic clamp that holds the positive battery cable. What set of holes does it attach to and what does the OEM rivet look like? Pictures would really help me with this one.
Second question is the placement of the vapor line and the fuel return line on the right side frame rail under the heater box/firewall area. On the back side of the front crossmember runs the brake line to the right front wheel, the vapor line and the fuel return line. It curves towards the back of the car immediately behind the crossmember. The brake line goes to the right front wheel at that point, but the vapor line and the fuel return line continue towards the rear of the car. My concern is under the heater box/firewall area. Are these 2 lines suppose to be on top of the frame rail or along the inside of it?
