More Miscellaneous and Hard to Find Parts
sumnerw
My three GNs are long gone and I'm finally getting around to selling my inventory of parts that I accumulated. All parts are new unless stated otherwise. Many of these are no longer available so here's your chance to stock up as I once did.
Pg and item number refer to the 1982-1990 44-W Illustration Catalog.
Prices are per piece unless stated otherwise. The number after the price is the quantity available.
Prices do not include shipping and insurance. PM me with your wants and your zip code for a shipping and insurance quote.
I prefer PayPal. Check my eBay feedback (sumnerw) - it is 100%.
All transactions will be on a first paid basis.
Keep an eye out for more listings - I still have a lot of stuff to dig out!
SPRING, RAD GRL RETURN (pg 1-10; item 10) GM #25516618 $20.00 2
PLATE, F/FDR (INTERCOOLED)(BX1) (pg 8-16; item 3) GM #25526372 $40.00 2
PLATE, F/FDR (INTERCOOLED)(BX1) (pg 8-16; item 3) USED GM #25526372 $20.00 1
PLATE, F/FDR (GRAND NATIONAL)(C01) (pg 8-37; item 23) GM #25516222 $70.00 1
PLATE, F/FDR (GRAND NATIONAL)(C01) (pg 8-37; item 23) USED GM #25516222 $35.00 1
PLATE, F/FDR (GRAND NATIONAL)(C01) (pg 8-37; item 23) USED - Some orange missing GM #25516222 $20.00 1
Body Mount Bushing - position #2 lower GM #457915 $10.00 2
Steering Column Collar (Shroud) (pg 6-54; item 14) - Gray - Used GM #25516001 $15.00 2
LAMP, PK & T/SIG-LH (pg 2-51; item 6) - Used - two cracks GM #5936629 $10.00 1
COVER, ESCUT PULL FRT DR UPR (PG14-25, ITEM 2) GM #20515632 $20.00 4
COVER, ESCUT PULL FRT DR UPR (PG14-25, ITEM 2) - Used GM #20515632 $15.00 1
Voltage Regulator for 120 amp alternator Echlin VR191 (replaces GM #1116411) $20.00 1
BEZEL, PK & T/SIG LP-LH (BLACK) (pg 2-51; item 7) - Used GM #25518984 $25.00 1
GUARD, BPR-RH (BLACK) (pg 7-25; item 18) Front - Used GM #25518990 $20.00 1
GUARD, BPR-LH (BLACK) (pg 7-25; item 18) Front - Used GM #25518991 $20.00 1
GUARD, BPR - RH (pg 7-33; item 4) Rear - Used GM #25505692 $20.00 1
GUARD, BPR - LH (pg 7-33; item 4) Rear - Used GM #25505693 $20.00 1
PLATE, RAD GRL NA "BUICK" (1987) (pg 1-10; item 11) - Used GM #25526879 $10.00 1
BUMPER, Trunk Lid (3/4" across flats, 11/16" diam., 1-1/4" long) - Used GM #12337963 $1.00 2
PLATE, RR BPR STUD (pg 7-25; item 20; pg 7-33; item 6) - Used GM #25526371 $5.00 4
SHIM, IMP BAR (STRAIGHT) (pg 7-25; item 3; pg 7-33; item 8) - Used GM #10024722 $1.00 8
CAP, W/O HANDLE FUEL TANK (GASOLINE) (pg 3-21; item 3) - Used GM #22525300 $5.00 1
ALDC Cover GM #10021766 $2.00 2
Valve Stem Caps - Gray $2.50 8
EMBLEM, STRG WHL "T-TYPE" (NQ5) (pg 6-54; item 12) - Used GM #25517763 $10.00 1
EMBLEM, STRG WHL HORN (TRI-SHIELD) (CHARCOAL) (pg 6-54; (item 12) - Used GM #25518979 $10.00 1
RING, HDLP RET (BLACK) (pg 2-51; item 18) - Used GM #5973455 $10.00 4
RING, HDLP RET (CHM) (pg 2-51; item 18) - Used GM #5966170 $5.00 4
Oil Feed Line to Turobcharger, with fittings for both ends (pg 0-48; items 108, 117 and 118) - Used $5.00 1
CLIP, OIL CLR PIPE (TO TRANS) - Used $2.00 1
CLIP, TRANS OIL PIPE (pg 1-12; item 3; pg 4-96; item 11) - Used $2.00 1
NUT, WHL (M12 X 1.5 SS/CAP) - Short - Used GM #14035301 $3.00 2
NUT, WHL (M12 X 1.5 SS/CAP) - Tall GM #9591701 $4.00 4
NUT, WHL (M12 X 1.5 SS/CAP) - Tall - Used GM #9591701 $2.00 1
Outer Front Wheel Bearing Race Timken SET 34 $5.00 2
Inner Front Wheel Bearing Race Timken SET 6 $5.00 2
ALDC Cover GM #10021766 $2.00 (1)
Oil Feed Line to Turobcharger, with fittings for both ends (pg 0-48; items 108, 117 and 118) - Used $5.00 (1)
CLIP, TRANS OIL PIPE (pg 1-12; item 3; pg 4-96; item 11) - Used $2.00 (1)
CLIP, OIL CLR PIPE (TO TRANS) - Used $2.00 (1)
Shipped to 78023, don't need UPS fast shipping.
Thanks.
Eschutcheon Cover
20515632 (Qty 1)-I'll take it.Will M.O. work ok? Thanks
How much for shipping on Valve Stem Caps - Gray $2.50 8
My zip code is 02771
Jack
The following items have been sold and are no longer avaiable:
The used Intercooled emblem
The used escutcheon (cover) for the door pull screws
All four bumper guards
The used Buick name plate for the front grill
Both ALDC covers
The oil feed line for the turbocharger
Both clips for the transmission oil tubing
