Motor mounts...what kind and where from?
camaro75racer
Noticed while installing the new tranny its time for some motor mounts in the GN. What's the best kind (something like Energy Suspension?) and where can i get them? Thanks for any help.
Cheap but good = autozone
Expensive but excellent = HR
You will never need a torque strap or ever have to buy another motor mount with HR.
Thanks for the quick reply's. Id rather do it right the first time and not worry about it so i guess ill be giving HR a call soon. Thanks again.
Dale
i have HR partsnstuff drivers mount installed so far. it was not a difficult task to do by myself in the driveway. i need to do my passenger side soon.
I have HR polymounts on both sides. Someone convinced me that the ps was causing too much vibration and setting off my knock sensor. I put an Autozone on the ps and noticed no difference as far as vibration. I did notice that the engine seemed to be twisting a lot more under the torque with the Autozone. I am putting the poly back on.
HNR.
I have one of the first runs in my car. I am sure they are even better now. Some vibration from mine, but not enough to bother me. I'd do it again in a second.
Find it hard to believe the mounts are setting off the knock sensor when my solid welded left side mount does not set off the knock sensor
HRs, solid but smooth. A must have in my book.
