I was wondering how I should hook up the 2 small wires coming off of the positive battery cable. I haven't traced them to where they go yet, but if I'm correct one of them is the ECM lead, right (the fusible link)?
I'm also installing a Flaming River disconnect switch (per NHRA rules) but don't like the idea of clearing the computer memory every time that I flip the switch off. Is there a way around this? Can I run the wires to the hot side of the switch so the 'puter doesn't loose it's memory (but that doesn't sound 'legal')? Also, should I run common 14ga wire from the back of the car to the fusible link or should I run fusible link wire all the way from the back of the car (if so, what rating of fusible wire)? And what kind of/gauge wire for the other lead?
I did a search for this topic but didn't find anything.
Thanks in advance.
Steve
Thanks in advance.
Steve
