MW15 nozzle ???
GN87-PV
I just purchased a slightly used SMC kit. It came with a M10 nozzle (which I assume is the original) and also a MW15 nozzle. The MW15 has a very flat open cone spray pattern (120 degee?).
Is there any advantage in using this wide pattern when the nozzle placement is 90 degrees to the airflow?
I dont think it matters. As long as they mist..there shouldnt be any difference. Now there is a flow difference between both nozzles. The 15 will flow like the 10 by lowering the pump speed.
HTH
Julio
