I want to congratulate this forum for the wealth of info you provided before I made my recent purchase
I have spent days upon days reading all that I could before I finally broke down and bit the bullet
I have been a Ford Person for along time but an admirer of GN's since the 1st time one put a serious whuppin on my 2000 Ford Lightning
I thought pickup trucks were sleepers, until this woman in a big black sedan killed me at a stop light in what sounded like a Hoover Vacuum Cleaner on Crack.....lol
I am looking forward to a long and lustrious relationship with this GN
My question is this:
The GN I purchased has the following setup;
Rebuilt Engine late 2002 (.030 over stock)
TA-49 Turbo
30 lb Injectors with Chip
LT-1 Mass Air Sensor with Translator
Adjustable Fuel Pressure Regulator with Gage
In Car Boost Controller
Vacuum Brake Mod
HP Fuel Pump W/Hot Wire
ERC rebuilt Transmission with 3200 rpm Stall
ATR 3" Down Pipe W/External Wastegate
High Flow Cats
Dual 2.5 " Exhaust
30 psi Pillar Boost Gauge
Auburn Posi Unit W / 3.42 gears
I am having a dual gauge pod installed below the radio (water / oil temp), along with a scanmaster V2.*
What am I missing with this setup, or what should I consider improving to obtain a streetable GN that will run low 12's / high 11's
Previous owner stated that he had hit 11.80 with this setup before the engine rebuild
Any advice at all will be appreciated
Ray
TA-49 Turbo
Vacuum Brake Mod
High Flow Cats
Dual 2.5 " Exhaust
Ray
