84ttypescreamer
- Oct 11, 2002
My 84 regal runs great when its cold but when you drive it for a while an get it hot if you shut it down it wont start again if you wait like ten minutes you can start it but i will run lousy its almost like its only running on a couple of cylinders but if you let it cool all the way down it will run good if you start it, it would run all day perfect but once you shut it down you cant get it back untill you wait till it cools down. The following are the things we replaced to try to correct this problem: fuel pump,fuel regulator,ecm,all the grounds have been cleaned and re grounded, plugs and wires,fusebox on the backside of the firewall all connections were cleaned and regreased.
if you have any info please respond, this car is geting to be a real headache
