i went to work, and left for lunch, when i got back i parked the gn in front of the shop, and when i ready to go home the car won't start, it turns over and wants to start but won't, had to floor the gas pedal to get it started for a little bit but dies, when you let go of the gas pedal, and then when you start it, after you floor it, i have to pump the gas pedal and then it starts to pop, and then dies, what gives, i check the fuel pressure and it like between 45 and 50 pounds, and when you turn the motor over, about 45 pounds,it was running fine just before i parked it, and when i was leaving to go home, just didnt want to start. i changed the module and coil, cause the module was melted, and was causing my car not to start. could it be my maf, or the connection, cam sensor, if it was the fuel filter, it would'nt have that fuel pressure hugh,
