my rear is saggging
zeljko
i replaced my rear shocks and springs on my 87 T type because they were original and were all worn out, not to mantion it had a slight sag on pasanger rear side. After i replaced them the sag is still there on the same side any recomindations or sugestions as to why.
how bout the body bushings, check them, I replaced mine and the car came up 1-1 1/2 ". I had to push the bumpers all the way up on the adjustments it came up so high.
Body bushings would be my guess also unless youre carrying extra weight in trunk,or in spare tire hole. has the car had body work on that side?
My first GN was like that also. My 2nd is getting worse. I think high boost launches may tweek the frame/body. Just stick an air-bag in there?
I had this same problem. I replaced the rear springs, and all of the body bushings, but I still had the sag. Believe it or not one of the front springs was bad.
all good advice, i havent the front shocks and springs but havent replaced them so i will start with that (didnt think that could cause it) and after if still sags ill lok into the bushings
thank you for great advice
