NAPA Spark Plug Wires
Buix893
Buick = $$$
Hey,
I want to replace my plug wires, and saw NAPA has a nice performance set. Now Im on a real budget, and is it true that it does not matter what plug wires to run? I have used taylors, and also the stock GM wires and have seen no diffrence.
cheap wires will arc or not conduct current as well as expensive quality wires.
I use NAPA wires on customer's cars all the time...I even have a set on my Dodge truck. They are good quality. That being said, I have Magnacores on my GN.
Get the autolite wires with teh lifetuime warranty from Advance autoparts and then change em when you like free.
Been using them for 5 years now with no problems and swap for a new set every year. I have only had a end tear off one time and thats cause it was my own fault.
I have tried MSD and Taylor ..I cant tell a difference honestly.
I think the term " KISS" comes into effect with plug wires. I am using stock delco plugs and ignition setup...so I doubt a bigger wire then stock will have any effect on a stock style ignition...:cool:
