Nati Beastcat's GN Project
Nati Beastcat
Party at the Moon Tower
Hello all,
I picked up my GN from a forum member on here last year. Its a California car and in great running condition with 44,000 miles on it. Turbo Lou kept the car in working order for the previous owner and helped me out over the phone while purchasing the car. 29 years of car washing, normal wear n tear and its time for paint! My friend Dave Jacobs will be taking it apart and making it look new again over the course of 4-6 weeks. He'll be fixing all the dents and dings. Removing all the chipped gravel guard from the lower part of the doors and quarter panels. And while he's at it.. new spool fool bumper fillers via Boost Crew Motor sports and shaving the front and rear bumpers. Once all that's done I'll tackle the suspension and new wheels.
Current setup:
SUSPENSION
Kirban Heavy Duty Springs, Front and Rear
Bilstein Shocks, Front and Rear
Aggressive Performance Sway Bar
ENGINE
Champion Ported Iron Heads
Nitrided H206-206 Roller cam kit w/Heat-treated Pushrods
B. Motorsports Cam Button, .005"
Cloyes Chain Set
Cometic Head Gaskets .060"
ARP Version 2 Fasteners (Head Studs, Main Studs, Wave-Loc Rod Bolts, Intake Bolts, Billet Steel Caps)
Full HP Bearing Kit
Harland Sharp 1.60 Roller Rocker Arms (Solid Shaft)
Morel Lifters
Wiseco Forged "Turbo" Pistons w/HD steel pins
42lb. Injectors
MAG Plug wires
RJC Billet Stock Crank Pulley, Black
RJC Billet Water Pump Pulley, Black
RJC Deep Sump Oil Pan
G-Body Parts 3-Core Aluminum Radiator
Kirban Billet Fuel Pressure Regulator
Kirban High-performance In-tank Replacement Fuel Pump Kit
TURBO
RJC Boost Controller
TurboTweak Chip
Razor Alky Injection System
GT6131E Street/Strip Turbo
PTE Stretch SLIC
Kirban CAI Kit w/ K&N Cone Filter
Kirban Adjustable wastegate actuator
TRANSMISSION
Rebuilt Transmission w/Billet Parts, Art Carr Kit
Vigilante 3200 Stall Multi-Disc TC
CPT TH2004R Aluminum Deep Pan
MISC
ScanMaster 2.1
Audible Knock Detector
Kirban Trunk Kit
Kirban Oil Filter Adapter
Kirban Driveshaft Loop Kit
Kirban Underhood Brace Kit
Kirban PCV In-Line Valve Kit
Day 1
All Trim removed from front and rear bumpers. Welding has started to remove holes. Spool Fool bumper fillers arrived. They haven't been fitted up yet but they look amazing! I've purchased a lot of aftermarket parts for various cars over the years. From a visual inspection the quality is beyond great.
slow and steady. Most of the glass removed, trim etc. and ready for what ever body work needs done. I'll be getting some nicer shots whens she's ready for the street again.
My car is in the exact same place,work looks good. Cant wait to get it back, hopefully this weekend if my paint guy works steady on it.
Nice. Can't wait to get mine back! Just in time for late spring and car shows and cruise in's
New Badges. second primer coat done and being blocked. Almost time for black paint!
