neat and a/c control
riviera
My heat and a/c contro won't switch from heat to vent to a/ it only blow on defrost and won't bring the a/c on. Not sure were to start to repair it
So the air is only coming out of the defrost vents but is still changing temperature? Or it's not changing temp either?
Yes it wll go from hot to co by moving the lower lever left to right but it only blow out the vent that defrost the widnsheid
Silver fox thaks for sending me that post just had a question my fuel pressur regulator was leaking gas from the vacum port on the regulator I just replaced it but do u think the gas might have caused a problem in my vacum system
I
Check your vacuum lines and check valve.
