need a trans pressure gauge
Warp6
Mine since '92
Whare can I find/order a transmission pressure test gauge with hose and correct fitting? Need to check pressure in the GN. Thanks, Craig
Thanks Russ! That's exactly what I'm looking for. I found one at Eastwood but it only reads to 300. Need one that reads to at least 350 and the one you linked to is up to 400psi. Perfect!
