Need BRF trans in need of rebuild, or good
Daniel Jost
Squirtin six
Anyone looking to get rid of a brf trans for a decent price, its fine if it needs a rebuild.
Thanks, Dan
I've got a BRF valve body.
I've also got a fresh trans with a BQ valve body, billet forward drum, 3 clutch OD, Alto reds in the direct, dual fed, chromoly pumpp rings, 10 vane pump, .500/.296 boost valves, and governor modded to achieve 5800-6000 rpm shifts. This unit worked well in my Chevelle, I pulled and rebuilt. It is currently installed in my Datsun V8 project with zero miles.
I'm near the DFW area in TX.
i have good unopened original brf cores for 400 if you cant use what jake is offering.
Also forgot to mention,
the BQ trans has a cast alum deep pan and Superior Super Servo.
how much u lookin to spend? i got a 200 with low miles and good parts. i hot lapped it at the track and burned up the 1-2 band. thats all thats wrong with it. i dont have a converter for it tho.
