Owlpond1
 - Oct 15, 2009
Just got my '85 back after a rebuild (Phil Bassage, did a great job) but the engine is not running properly.  Trying to sort it out on my own without going back to him.  Engine barely idles/stumbles at idle and at about 4500 rpm completely cuts out (seems running rich) and has no power.  Has great power from a rolling stop and at top end but really stumbles and blows black smoke in the mid-range.  I have no scan tool.  Here's what I've done (and assume everything that went back on the motor was good).
Installed new TPS (Holley) and have it set to .43 volts at idle and 4.9v at WOT.
Have tried with MAF disconnected and connected but no difference.
Has an '87 coil pack but otherwise all stock.
Next move is to upgrade ECM so I can connect a scan tool and get to the bottom of it.
Thoughts?
Thoughts?
