need help asap!!
87gnNV
i just bought the racetronix fuel pump with the hot wire kit. Do i also need to buy a fuel pressure regulator or is the stock good enough? The gn stock. thanks
fuel Reg.
well, the stock one is OK but getting to be about 15 years old so even replacing it NOW is a good idea. However, most people replace them anyway when going to a bigger pump as most people intend on turning up the BOOST. SO, it's a good idea to have a reg. that is adjustable whereas you can TURN UP your fuel pressure. MORE BOOST = MORE FUEL. HTH....
John C.
LedSLED Motorsports
Not necessary now, but when you want to bump up boost and/or put in a chip, you will need more fuel pressure. I'd do it just for cheap insurance.
