ez at nova
I hate rice
- Jun 4, 2001
Last night I took off from a light somewhat vigorously (3/4 throttle) and the car shifted fine. My car has a kit in it, so it always bangs into second and chirps the tires if you’re even mildly on the throttle. The next time I pulled away from the light, when the car went to shift into second, it felt like my Grandma’s 88 Cutlass, I couldn’t even feel it. I was hoping it was a fluke. I gave it gas to make it downshift to first and when it did it sort of “rubber banded” and got all mushy, the revs went up but the car didn’t go anywhere for a few seconds. At the next light, as the car was sitting, it got a bit shaky like it wanted to stall or couldn’t find the right idle revs or something. Now it’s the same thing each time I pull away, it seems to be slipping in the 1-2 shift. It may be my imagination but I think it’s a bit harder to move the shift lever now, and I think it was stinking a bit, like a burning smell when I got home, and it might “clunk” a bit more when I put it in gear, from R, to N ,to D, but it did always sometimes “clunk”. The car SEEMS to be fine after it gets past the 1-2 shift.
Also, should I try to drive the car too where ever I’ll need to end up going for a fix or should it not be driven for fear I blow the whole thing up or make it worse or something?
If it matters for your repair recommendations, my car is running the stock converter. It is a 95% street driven car.
Ah, and just days after getting a new water pump in.
Thanks,
Jeff
Thanks,
Jeff
