need help
1bad84gn
just got car back together idles & runs fine in park but when you drive it there's a miss & back fires. Any ideas? thanks jim
When you say you just got the engine back together what mods were done if any let us know every thing to help you better good luck
Anthony
motor is stock has 30lb. inj.,adj fuel reg. & a 255 fuel pump. The fuel pressure is set at 40 tps is set at .41 thanks jim
