Need Help
Dustin27987
I recently cleaned out my plenum and throttle body, put new plugs and plugwires, changed the oil and filter, and put a new fuel filter in the 87 GN. I started it up and it seems like it has a miss and the check engine light is on. It does go off though when rpm's are greater the 3,000. When i drove it it also cut out when i got on it. Any ideas as to whats up?
Did you clean the parts while on the engine, or did you dis-assemble them first?, also did you put the fuel filter on backwards?
