Need more info. on PAC controller operation
EVO8LTW
Can someone explain how that PAC controller works? I see a dial and a button on one box and I'm not sure what they do. What is the little black box is on the right and what is the box that says PAC? And what is the red LED between the dial and button? I've done a search and can't find any better pictures or description of the various dials, buttons and LEDs on the alkycontrol progressive controller. Here's the photo from alkycontrol.com
Thanks,
RichJ
There are three controls. Two are internal, one is external. The internal controls setup when it fires, and how aggressive at time of firing. The external control works directly off of the input signal and its rise in drive to the pump with signal increases.
You can say its 3 dimensional.
The black push button simulates it turning on at its "turnon" point.
The red LED on the panel simply shows an on/off condition. So if a fuse were blown or??? That LED would be out. There is another LED that shows system has fired.
Very simple.
HTH
