Ok.... tell me if this is a good idea / or if it might work.
Take a 8.5:1 350 or 383... put a holley commander 950 MPI complete system..........list any potential problems I might run into bringing two pressureized pipes into the throttlebody..... maybe vortec heads if you want to stay fairly low buck...a cam cut for turbo setup (could even be hyd. cam to keep costs down)..... not too hot.... power range to 6000 would suffice....2 stock GN turbos...(should be able to find these used and relatively inexpensive.... they also have integral wastegate)....2 stock GN intercoolers.....(also easy to find and relatively inexpensive)...... I was thinking about 800 hp @ rear wheels would not be too much to ask out of this combo on pump gas.
