need some fine tuning help
unfair
hey guys, i'm really enjoying my alky kit, but i have 1 problem. the alky is coming on too hard in the upper rpms and really dropping my AFR's. i'm running the alkycontrol kit and i'm also using the MAFTPRO for my tuning.
i'm wanting to run 28psi and i really don't want to starve the motor of alky. the power feels great but after 4700 rpms the motor is going pig rich. right now i have the progressive knob on the 6 0clock position (test button facing on left)
all other setting have not been touch. here a dyno at 24psi and you can see and the car getting really rich; the power falls off. should i back off the alky or pull more fuel? also on these run i was running 100% denatured alcohol cause i could find any methanol..
on the the graphdynograph
Pull fuel. Drop injector duty cycle.
One thing my car didnt like was the volt booster, if you have one.. try the car without it.
Never pull alky unless its laying down in power and keeping AFR.
Your injectors need to be leaned out. Easy :)
thank you for the fast response. i will remove some fuel in the upper rpms
