Need to borrow knwn good MAF...possibly ECM, ICM and Coil pack
Tim,
I've got most of what you need. I have a good MAF, several coil packs, several ECM's a coil pack tester, Ohm meter etc. The only problem is that I'm down in San Diego. If I can help you out let me know.
Neal
Tim,
Neal
Thanks, Niel.
I appreciate it.
If I can't get anything closer I'll let you know.
had similar problem when the TPS would get up to temp. anything over 1/4 throttle the TPS values would drop to 0.2 v. did not have any SES lights, just a lot of jerking when ever i would give it the gas.
I just let the car warm up this AM and every several seconds it will stumble at idle. I tapped on the MAF while it was idling smooth and it would induce a stumble...
I have not tried to drive it with the MAF unplugged, but at idle if I unplug it, the RPM drops from about 850 down to 675 or so. If I let it continue to idle with the MAF unplugged, it eventually stumbles so bad it wants to stall. The BLM's stay pegged at 116 at idle whether the MAF is plugged in or not and at idle the cc's are at 181 and not moving.
I checked the TPS wit the engine off. It's pretty linear. Starts at .42 and sweeps nicely up to 4.56 at WOT.
Thanks Al.
Lou will be back in a few days, so I'll probably wait to use one of his since he's so close by.
Thanks Al.
I,m in N.M right now & on my way to Phoenix visiting Guy & would like to stop & say hello to Nick Michale. Z06 is running well getting 27-30 MPG got one eye on the road & the other on my radar detector. So Chicken try & hold out till Thursday when I get back.
You still running that Impalla SS MAF that I sold you? I've got a good stock MAF. You check the cam sensor?
The Chicken is down.
Mike B.
Who the hell asked you to come to Phoenix wich yo' raggedy ol' Corvette, old man? :biggrin:
It better be clean when you bring it here.... Don't make me look bad to my neighbors........;)
Mike B.
Wow!
That chit is COLD.........BRRRRRRRRR.
No rush Lou. Enjoy the drive...I don't want to get blamed for any court appearances.... ;)
Frozen chicken
It's the McNuggets that are suffering the most....
Mike B.
I'm still running the stocker that came on the car...haven't bought a Maft Pro yet...but I might be in the market for one come Thursday...
I pulled the cam sensor cover tonight...all looks good in there...
Can you bring your spare stock MAF to your shop tomorrow? I'll swing by and pick it up to see if it fixes the issue, and then bring it back to you the next day.
No problem. I'll leave it out back of my shop in the usual place.
Mike B.
Mike B.
Hey Mike,
I stopped by but could not find the part.
...but as luck would have it, as I left the parking lot, I found some homeless guy holding on to a cherry OE MAF for an 87 GN. He appeared to be getting ready to smoke some weed through it.
I gave him $5 bucks for his pipe...and through in an empty Coke can for him to use as his bong...a total win-win-win!!!
He gets to get his hits in (winning!)....I helped to recycle an aluminum can for the environment (winning!!)...and I have a nice MAF to replace my busted one with (winning!!!)
Can't wait to get home and try it out.:biggrin:
That was it...bad MAF.
Hey SPOOLFOOL2...thank that homeless guy hanging out near your shop for the great deal on this MAF. I won't need to borrow yours after all...:biggrin:
