Need to know firing order of my GN?
WH1
5150
I need to know both the firing order of my 87 and the order of the coilpack posts. I replaced my plug wires according to an old post and the old wires didn't even come close to matching this order.
Driver side: 1 3 5
Pass Side: 2 4 6
Thats the cylinders
Plug wire order is 1 5 3 on the driverside to either side of the coil, and 4 2 6 on the other side. If the coil is hooked up to the module right, you can switch to either side of the coil but keep the same order. Hope this helps
