CAR IS FINALLY READY FOR INSP. EXCEPT IT DID NOT HAVE BKUP LIGHTS, WHICH I WOULD GET GIG FOR. SO I REPLACED THE SWITCH BUT NOW I HAVE BK UP ALL THE TIME WHAT AM I MISSING THANKS IN ADVANCE
If it is a stock setup, the switch adjusts by rotating it. Since you changed it, I assume you know where it is Simply rotate it until the backup lights are only on when in reverse. Also check that you can start the car in only neutral and park as this switch does both duties.
