The 4.1 block is Gloss black which was then cleared. It is bored .30 over with new speed pro pistons (hypers), std std turbo crank balanced and polished, 2 dot turbo rods reconditioned and balanced, 8445 turbo heads fully ported and polished with new stainless steel ferrea 1.77 intake 1.50 exhaust valves, lt1 valve springs, new double roller timing chain, new 204 214 flat tapet cam with matching lifters, new arp head studs, all arp bolts on the bottom end as well. Head work and motor work was all done at RPM in Tenn. by Dewayne (A grand national motor builder). oil pan has the fitting for the turbo return hose, front cover has been cleaned and painted (looks like new), stock balancer, stock flywheel, stock rockers (not on heads), stock push rods (not on heads). Everything is Fresh and brand new never run! This would be a great replacement for a 3.8 to get that turbo spooling faster! should be good to low 11's with no problems with some high 10's on a Excellent tune and the right setup. I will take better pictures when I wake up in the afternoon.
Located in Atlanta, GA. I have no exprience with shipping something like this so you would have to help, if you would like it shipped. I am asking 1300.00 which is a steal being that the heads are worth 800 plus alone! not including all the other parts and machine work!! This block was built right!!! this is no JUNK!
