Installed new long block...with new crank sensor, and a very slightly used cam sensor with Casper's cap. Original wire harness
Engine fired up immediately...no issues. Over the next few days finished a few details and then took it for it's first drive today. Again fired right up...drove it about 1 mile...no hot rodding, 40MPH max, then let it idle for about 10 minutes. Then shut it off.
15-20 minutes later attempted to start if to pull into garage and it cranked over fine but not a hint of firing. Hit the key 5-6 times....each time cranked fine but no fire...not even a weak cough.
Pushed it into the garage...thought and researched it for 2 hours.
Removed #1 plug, attached the plug wire to the plug, and laid it on the valve cover. Cranked it over watching the plug for spark and it started immediately. Shut it off...reinstalled the plug and wire and cranked it again.
Started, then it would not start, started, started, started, started, did not start, and started again on my final attempt. All of these starts or attempts were done in a total of 30 seconds or so. Had good fuel pressure whether it started or not.
Ideas??
Thanks, Bob
Ideas??
Thanks, Bob
