I am having problems with my system also. The brakes would come and go. And mostly go.
The Brake fluid was brown. I changed it out and I replaced the Iron Proportional valve with the new brass one. Now I have clear fluid. But My brakes still come and go. I think the accumulator is bad. The brake light will come on when I 1st hit the brakes. Plus if I do the 10 pumps then turn the key on the motor only runs for 1 or 2 seconds. The GM test procedure says this means the Accumulator is bad.
I now have the new accumulator. I am concerned about installing it. There is a label in it saying Caution Pressurized to 300psi with Fluid. After I depressurize the old one and unscrew it, I am wondering if I will have a problem screwing on the new accumulator being that it is Pressurized.
Any opinions on how to install the accumulator?
