I am an english teacher can't you tell Bob???
I bought the nitrous harness from F.A.S.T. It has two relays in it. It has two wires that are for nitrous activation. One for 1st stage (orange) and the other is for 2nd stage (brown). I followed the
instructions for wiring it . There are only four wires total. I only use three of those.
This is where it gets confusing. I don't know what to do with the orange wire for the 1st stage nitrous in the F.A.S.T. harness. I ASSumed it would go to soleniod. Then the other soleniod wire would be ground (per the instruction). No voltage to soleniod, but F.A.S.T.  sees nitrous enable and activation which retards timing and adds fuel.
I have the relay that the fans were run through. So I  wired it so the fast box grounds (black- fan wire) the relay and the relay sends voltage to the nitrous solenoid. The wires on the relay that can send voltage are the yellow or brown, with one them being battery and the other hooked to the solenoid. Red is the 12 volt switched.
I don't know if this is right. I don't know what would ground the black wire in the box if this was for the fan. I changed my fan on setting to 0 but the default is 36. No nitrous activation but I DO have fuel enrichment and timing retard.
I ended up putting the nitrous soleniod on a push button and let the controller retard the timing and add fuel,. I needed
 to use  the nitrous Sunday and had no choice. I can get help from F.A.S.T. next week. This is not good early nitrous... KABOOM, late nitrous... fat till it clears.
It will work... I tried it tonight
 .... But I must hold the button down for the nitrous.
