G
gp406Z
Guest
I have a 406sbc that I`ve got running well with the FAST system and I`m ready to use my wet nitrous kit. I know the jetting will be on the rich side and I need to know how to correct it. Should I leave it in closed loop,allowing max rich/lean correction,overlay that and aply how much it corrects to my VE or should I jet down the fuel side of the kit? Again allowing max corrrection till I get the desired A/F. I know it should not be allowed to remove fuel in the top/WOT rows of the table and was wondering if I could do it this way to tune,then disable that correction when it`s right.
Also, my kit uses an arming switch,WOT switch,and fuel pressure safety switch for operation.How should I wire in FAST ?
Glen
Glen
