NLU wiring?
SIXBANGR
mean old man
do you still need the wires hooked up if you go with a nlu convertor? The ones to to lu valve and the ones to the other switches inside the pan?
The 2 switches in the VB are for 3rd and 4th gear. If they are not hooked up the ECM doesnt know its in either gear. Can affect cruise control, chip adjustments , etc
just got out from under this thing. The plug is not plugged in. Had the car car 4 month's and drove it from Washington to kansas like this. Cruise works fine, don't know about any thing else it has been doing.
Your L/U isnt working for sure then. Should notice about a 200 rpm drop with it plugged in and the l/U engaging
