no alky under boost
Heath
Elroyjr
I installed Razor kit on my dads car but the alky will not kick on under boost. It works fine when you push the test button. Did I hook the signal wire up wrong :confused:
Map sensor issue. Re-read the instructions pertaining to the 3 bar MAP..
You can always call during the week ;)
Same problem here, my wonderful solder job broke. Re-soldered and its all good.
no alky at boost
I thought about that I am going to check that now thanks.
