Baron Von Buick
Big White Guy
- Jan 30, 2003
I just put a system in my car, Sony Xplod radio 300w Jensen amp and 2 12"'s. It worked fine until i had to disconnect the wires from the back of the radio so i could put on the kit to fit the radio in the console, now this is what i did- removed the wires for the adapter to the radio, removed the memory wire from the lighter wire, removed the amp wires and the gorund from the radio and remove the wire that gives power to the amp and fan then i put the face on plugged everything back in turned on the radio and i only had power to the inside speakers, no power to the fan, amp or subs, i checked the fuse in the radio, amp, every fuse under the dash and every wire for the radio that i dissconnected and i also changed the 80amp fuse from the wiring kit for the amp and subs and i still have no power to the amp, fan or subs! PLEASE someone tell me they know whats wrong. BTW i used the system for a total of 20 mins. and not loud.
Patrick
Patrick
