LAMMONS0003
- Nov 11, 2010
1984 T type 206/206 cam kit with lifters and springs from comp. fuel pump hot wire.
After doin cam break in and a several times of letting run in my garage i decide to go on a road test. I made it 4/10s of a mile before it died after sputtering and wont start for anything. I have spark and 38lbs of fuel pressure but dont think my injectors are cycling. I pulled a plug and it appeared dry as can be after several times cranking engine over. All i get is a few random pops out of the exhaust. I have set and reset my cam sensor several times. i am goin to adjust the air gap on my crank sensor also. What is the best way to test the injectors if they are workin properly. I have no codes also. I understand the cam sensor sends signal to the ecm thru the ignition module to power the injectors. Wheres best place to start?
