nozzle
jerrad
i put in a alky control kit and i put the nozzle right before the throttle body about 1/8 of an inch from the rubber hose and clamp is this an ok spot for the nozzle?
Why not? As long as the hose reaches from pump to nozzle, and you can have room for turbo inlet hose, iac plug, shut hood, etc. Spray Away your detonation blues!
Actually as long as the nozzle is higher than the alky tank level.. anywhere you like is all the same.
Top.. bottom..side.. no matter.
Do a length check on the hose before getting too carried away. If you drilled the hole.. and now your hose doesnt reach.. drop me a call and i'll get you a longer hose. ;)
Julio
What happens if the nozzle is lower than tank? Doen't the pump have a one way valve in it somewhere? I don't understand the problem.
Yup has a one way valve.. guess what direction it flows?
:D
Guess ya never siphoned gas out of a lawnmower.. one hose has to be at a lower point to get the fluid going rite? ;)
In other words if you mount it (the nozzle) lower than the level in the tank the one way check valve will permit it to drain out all your alky.
Derek:cool:
Well since your getting technical :D
The one way check valve doesnt let your tank get bubbles and push air into the lines.
And is whats responsible for assisting the pumps auto-priming function ;)
That too!! But I didnt want to get too technical, j/k.
Thanks Julio,
Derek:cool:
