O2 Correction
MSDGN
How do I modify the O2 correction in XFI...I want to lower it for both plus and minus...
I think i can answer this one...
Go to View->Closed Loop Parameters-> Correction Limits
Then just change the numbers in the cells that you want corrected. If you put 5 in, it will be the upper and lower limits of correction for that cell.
If you do not see this you will need to go to File->Menu Mode and click on Advanced. Then do the first step i mentioned again.,
Hope this helps
Adrian
