OneLethal87GN
R.I.P. Lethal GN
- May 26, 2001
The main time it does this is at idle. It had gotten worse lately and now has a long delay after I punch it. I did a search and tried the cam sensor and tried to check fuel pressure but my gauge leaks. The sensor isn't too much more than a month old. I tried different chips as well. It will stay below 100, mostly at 000, until I give it some gas. Then it will slowly come up and act normal. While cruising, it is fine. When I let off during cruising, it goes back down to 0s again. Nothing but 93 gas has been used. This is really annoying since it seems to want to, and has, cut off at the light. I've watched my SM readings for all sensors and all seem fine except for the O2 readings. Any suggestions?
