O2 numbers while driving
radtech
What are the O2 numbers while traveling under partial throttle. My seem to be around 480 when doing a steady 65 MPH. Thanks!
480-800-22-75-96-562-985-785....about any number you can think of. O2's at cruise arent very important really. O2's at WOT are a whole different story. Look at CC (Cross Counts) to see how the sensor is functioning. As in, it should cycle from 0-255 while cruising. If it takes a long time for them to change, then the o2 needs replaced.
-Adam
They should cycle from low to high. If they stay steady around 480 then you may have a dead O2.
They go all over the map. I just was wondering about the 400-500 while cruising
