How does the tank vent work with the small filter? Gas fumes? I was gonna do something similar, but raise the height with more tubing first. Mebbie make it loop up just under the top of the fender
We have mountains here in AZ. and I am concerned about long down hill runs and if I have to brake hard due to the "flatlanders" driving slow due to fears of "falling off of the mountain."
We have lots of steep grades here with no "ARMCO."
The previous owner removed the vapor cannister and CAPPED THE VENT!
Is there another vent in the rear, like in the older cars, behind the rear seat? Or is this the only vent? If so, then the cap is as stupid as other things I have found!
Also, the big vacuum ball was in the trunk, where is the stock location, and where should it connect? My car has cruise control. Should I "T" it off of that? Or into the HVAC system? They both have separate vacuum connections. Thanks for any info!
The last owner had FOUR different shops work on it after the "new motor" was installed, none of them could even make it run! I am going thru every circuit, hose, nut, and bolt, before I try to drive it!
TIMINATOR
